Demontaz/montaz radia ve FF II
newim123
Re: Demontaz/montaz radia ve FF II
Příspěvek od newim123 » 10.10.2017 11:47
Mam takovou otazku k cemu jsou tyto dva kontektory? Diky
ScorpionSX
Příspěvek od ScorpionSX » 10.10.2017 12:24
Connector A (Speakers & Power)
Pin 1 – Rear Right +
Pin 2 – Front Right +
Pin 3 – Front Left +
Pin 4 – Rear Left +
Pin 5 – Rear Right –
Pin 6 – Front Right –
Pin 7 – Front Left –
Pin 8 – Rear Left –
Pin 9 – CAN Bus +
Pin 10 – CAN Bus –
Pin 11 – Keycode Ground
Pin 12 – Ground
Pin 13 – Alarm Sensor
Pin 14 – Illumination
Pin 15 – Battery 12v + (Permanent Live)
Pin 16 – 12v Ignition Live
Connector B (Aux 1)
Pin 1 – Mono +
Pin 2 – Sw A +
Pin 3 – Aux In Left +
Pin 4 – Aux In Right +
Pin 5 – PTA
Pin 6 – SWC (Steering Wheel Control)
Pin 7 – Mono –
Pin 8 – SWC Ground
Pin 9 – Aux In Left –
Pin 10 – Aux In Right –
Pin 11 – Reverse Sensor Signal
Pin 12 – AVC (Speed Control Volume)
Connector C (Aux 1)
Pin 1 – RSE Left +
Pin 2 – RSE Right +
Pin 3 – Mono 2 +
Pin 4 – Sub Woofer +
Pin 5 – Aux 2 Left
Pin 6 – Audio Ground
Pin 7 – RSE Left –
Pin 8 – RSE Right –
Pin 9 – Mono 2 –
Pin 10 – Sub Woofer –
Pin 11 – Aux 2 Right
Pin 12 – Mic
